Engineering Solutions
Saving a File
Saving a File
Saving a File
The simplest way to save a .hm model database is to use the Save or Save As options located in the File menu.
Save simply saves the current model under its current name, updating/overwriting its older version each time you save.
Save As invokes the file browser so that you can navigate to the desired file directory and type in a name for the file to be saved.
See Also:
Retrieving and Saving a File
