Engineering Solutions
PAM-CRASH 2G to RADIOSS Conversion
Use the Conversion tool to convert a PAM-CRASH 2G file to a RADIOSS file.
1.Load the PAM-CRASH 2G user profile.
2.Import a PAM-CRASH 2G model.
3.To run the conversion macro, from the menu bar, click Tools > Convert > Pam Crash > To RADIOSS. The Conversion tab opens.
4.For Destination Template, select the destination solver version.
5.To start the conversion, click Convert. After the conversion, the RADIOSS user profile automatically loads.
6.Review and export the deck using the RADIOSS user profile. Some of the keywords in the PAM-CRASH 2G deck are converted to the RADIOSS deck as per the following tables.
Elements
HM configuration,
PAM-CRASH 2G type
HM configuration,
RADIOSS type
BAR
TRUSS
BEAM
BEAM
SPRING
SPRING
SPRBM
SPRING+PROP/SPR_BEAM (TYPE 13)
MEMBR
SH3N, SHELL
SHELL
SH3N, SHELL
SOLID
BRICK
TETRA44
TETRA44
MASS
ADMAS
PLINK
SPRING+INTER/TYPE2
KJOIN
SPRING+PROP/KJOINT(TYPE33)
Boundary Conditions
HM configuration,
PAM-CRASH 2G type
HM configuration,
RADIOSS  type
INIVEL
INIVEL
BOUNC
BCS
CONLO
CLOAD
System Mapping
HM configuration,
PAM-CRASH 2G type
HM configuration,
RADIOSS type
FRAME
FRAME
Material Mapping
HM configuration,
PAM-CRASH 2G type
HM configuration,
RADIOSS  type
MAT_1D TYPE 201
M1_ELASTIC
MAT_1D TYPE 220
/PROP/SPRING
MAT_1D TYPE 223
/PROP/SPR_BEAM
MAT_2D TYPE 100
M0_VOID
MAT_2D TYPE 101
M1_ELASTIC
MAT_2D TYPE 102
M36_PLAS_TAB
MAT_2D TYPE 103
M36_PLAS_TAB, M44_, COWPER
M2_PLAS_JOHNS
Curve Mapping
HM configuration,
PAM-CRASH 2G type
HM configuration,
RADIOSS type
FUNCT
FUNCT
Control Cards Mapping
HM configuration,
PAM-CRASH 2G type
HM configuration,
RADIOSS  type
TITLE
TITLE
OCTRL/
DSYOUPUT
/ANIM/DT
THPOUTPUT
/TFILE
Component Mapping
HM configuration,
PAM-CRASH 2G type
HM configuration,
RADIOSS type
PART
PART
Contact Interface Mapping
HM configuration,
PAM-CRASH 2G type
HM configuration,
RADIOSS type
CNTAC36
INTER/TYPE7
Rigid Wall Mapping
HM configuration,
PAM-CRASH 2G type
HM configuration,
RADIOSS  type
RWALL
RWALL
Time History Definition Mapping
HM configuration,
PAM-CRASH 2G type
HM configuration,
RADIOSS type
THELE
TH/SHEL, SH3N, SPRING, BRIC
THNODE
TH/NODE
THLOC
TH/FRAME/ACCELEROMETER
Section Definition Mapping
HM configuration,
PAM-CRASH 2G type
HM configuration,
RADIOSS type
SECFO
SECT
Group Definition Mapping
HM configuration,
PAM-CRASH 2G type
HM configuration,
RADIOSS type
GROUP
GRNOD
Airbag Definition Mapping
HM configuration,
PAM-CRASH 2G type
HM configuration,
RADIOSS type
BAGIN
MONVOL
The attributes converted in each KEYWORD is explained in the Conversion dialog (see below). Each keyword is associated with a color to distinguish it better.
GREEN – All the attributes of the KEYWORD are converted to equivalent in RADIOSS.
ORANGE – Only some the attributes of the KEYWORD are converted to equivalent in RADIOSS.
RED – None the attributes of the KEYWORD are converted to equivalent in RADIOSS.  Conversion of this keyword is not supported by the conversion tool.
Conversion_tab
