Engineering Solutions
OptiStruct to RADIOSS Conversion
Use the Conversion tool to convert an OptiStruct file to a RADIOSS file.
1.Load the OptiStruct user profile.
2.Import an OptiStruct model.
3.To run the conversion macro, from the menu bar, click Tools > Convert > OptiStruct > To Radioss (Block Format). The Conversion tab opens.
4.To start the conversion, click Convert. After the conversion, the selected version of the RADIOSS user profile automatically loads.
5.Review and export the deck using the RADIOSS user profile. Some of the keywords in the OptiStrut deck are converted to the RADIOSS deck as per the following tables.
Element Mapping
OptiStruct type
RADIOSS type
CONM2
/ADMAS
CWELD
Mesh less weld
(feabsord, fe realize using HEXA)
CELAS1/CELAS2
CDAMP1/CDAMP2
(0 length)
/SPRING
PLOTEL
Plot element
RBAR
/RIVET
RBE2/RBE3
/RBODY
RJOINT
/RLINK
CBUSH
(When using vector)
/ SPRING3N
CBUSH1D
/SPRING2N
CBAR/CBEAM/CBEND
BEAM
CROD
TRUSS
CONROD
TRUSS and /PROP/TRUSS
CTRIA3/CTRIAR
CTRIA6
(Change to 1st order before convert)
/SH3N
CQUAD4, CQUADR, CSHEAR
CQUAD8
(Change to 1st order then convert)
/SHELL
CTETRA4
CTETRA10
/TETRA4
CHEXA8/ CPENTA6
CHEXA20/ CPENTA15
/BRICK
Property Mapping
OptiStruct type
RADIOSS type
PBAR/PBEAM
(Only single section PBEAM is supported)
/PROP/BEAM
PBUSH
/PROP/SPR_GENE
PBUSH1D/PDAMP/PELAS
/PROP/SPRING
PROD
/PROP/TRUSS
PSHELL/PSHEAR
/PROP/SHELL
PSOLID
/PROP/SOLID
Material Mapping
OptiStruct type
RADIOSS type
MAT1
/MAT/ELASTIC
MAT8
/MAT/LAW19
See Also:
OptiStruct Conversion Tools
