Engineering Solutions
OptiStruct to LS-DYNA Conversion
Use the Conversion tool to convert an OptiStruct file to a LS-DYNA file.
1.Load the OptiStruct user profile.
2.Import an OptiStruct model.
3.To run the conversion macro, from the menu bar, click Tools > Convert > OptiStruct > To LsDyna. The Conversion tab opens.
4.For Destination template, select the destination solver version.
5.To start the conversion, click Convert. After the conversion, the LS-DYNA user profile automatically loads.
6.Review and export the deck using the LS-DYNA user profile. Some of the keywords in the OptiStruct deck are converted to the LS-DYNA deck as per the following tables.
Element Mapping
OptiStruct  type
LS-DYNA type
CONM2
*ELEMENT_MASS
CBAR
*ELEMENT_BEAM
CTRIA3,CQUAD4, CQUAD8, CTRIA6
*ELEMENT_SHELL
CTETRA4/CHEXA8/CPENTA6
*ELEMENT_SOLID
RBAR
*CONSTRAINED_SPOTWELD
PLOTEL
*ELEMENT_PLOTEL
RBE3
*CONSTRAINED_INTERPOLATION
RBE2
*CONSTRAINED_NODE_SET
CELAS1
*ELEMENT_DISCRETE
Property Mapping
OptiStruct type
LS-DYNA type
PSOLID
*SECTION_SOLID
PSHELL
*SECTION_SHELL
Material Mapping
All the LS-DYNA materials are mapped MAT1 in OptiStruct.
Boundary Conditions Mapping
OptiStruct type
LS-DYNA type
SPC
*BOUNDARY_SPC
FORCE, MOMENT
*LOAD_NODE_POINT
PLOAD4
*LOAD_SEGMENT
TEMP
*INITIAL_TEMP
Coordinate System Mapping
OptiStruct type
LS-DYNA type
CORD1R
*DEFINE_COORDINATE_NODE
CORD2R
*DEFINE_COORDINATE_
SYSTEM
See Also:
OptiStruct Conversion Tools
