Engineering Solutions
OptiStruct to ANSYS Conversion
Use the Conversion tool to convert an OptiStruct file to an ANSYS file.
1.Load the OptiStruct user profile.
2.Import an OptiStruct model.
3.To run the conversion macro, from the menu bar, click Tools > Convert > OptiStruct > To Ansys. The Conversion tab opens.
4.To start the conversion, click Convert. After the conversion, the ANSYS user profile automatically loads.
5.Review and export the deck using the ANSYS user profile. Some of the keywords in the OptiStruct deck are converted to the ANSYS deck as per the following tables.
Materials
OptiStruct  type
ANSYS type
Convert Parameters
MAT1
MPTEMP/MPDATA
E, G, NU, RHO, A, GE, TREF
MATT1
MPTEMP/MPDATA
T(E), T(G), T(NU), T(RHO), T(A), T(GE)
MAT2
MATERIAL
density
MAT4
MATERIAL
density
Elements
OptiStruct type
ANSYS type
HM Configuration
CONM2
MASS21
Mass
CELAS1
COMBI14
Spring
CBEAM
BEAM188
Bar2
CBAR
BEAM44
Bar2
CROD
LINK8
Rod
CTRIA3, CTRIAR
SHELL181
Tria3
CQUAD4, CQUADR, CSHEAR
SHELL181
Quad4
CTRIA6
SHELL281
Tria6
CQUAD8
SHELL281
Quad8
CTETRA
SOLID45
Tetra4
CTETRA
SOLID95
Tetra10
CHEXA
SOLID45
Hex8
CHEXA
SOLID95
Hex20
CPENTA
SOLID45
Penta6
CPENTA
SOLID95
Penta15
CGAP
CONTACT52
Gap
CBUSH
COMBI14
Spring
Properties
OptiStruct type
ANSYS type
Convert Parameters
PBEAM, PBEAML
SECTION
See note #1.
PBAR, PBARL
BEAM44p
None. Only creates a property card.
PBUSH
COMBI14p
k1 to k6, GE1 to GE6
PELAS
COMBI14p
k, GE
PGAP
CONTACT52p
U0, KA, KT, MU1
PROD
LINK8p
None
PSHELL, PSHEAR (tria3, quad4)
SECTION
See note #2.
PSHELL, PSHEAR (tria6, quad8)
SECTION
See note #2.
PSOLID (tetra4, penta6, hex8)
SOLID45p
None
PSOLID (tetra10, penta15, hex20)
SOLID95p
None
ETType of ANSYS
If the model contains OptiStruct elements which were mapped to MASS21, LINK8, COMBI14, BEAM44, SHELL181, SHELL281, SOLID45 and SOLID95 elements, respective ETTYPES will be created and assigned to the component. Key options of ETTYPE are not updated.
Components
If the component collector contains different type of configuration of elements, new components will be created for the respective configurations and those elements will be moved into the new component. ETTYPE, material, and realset section IDs will be assigned to the new component.
Loads and boundary conditions
Loads and boundary conditions will not be converted by using this conversion tool.
Conversion of contact surfaces
Conversion of contact surfaces: If in OptiStruct a contact pair's master and slave are both contact surfaces (CSURF), then the contact surfaces and the pair will be retained after conversion. However, in Ansys, you must add the details for the surfaces, such as Et type and property card. If the friction coefficient MU1, available in the OptiStruct property card, is attached to the contact pair, then a new material card with a MPDATA card image will be created, and the value will be mapped to MU in the Ansys format after conversion.
Note #1
If CBEAM is associated with PBEAM/PBEAML, then the properties within those cards will be converted to ANSYS SECTION with type BEAM. OptiStruct beam cross sections of types: BAR, CHAN, HAT, I, L, T, ROD, and TUBE are converted to ANSYS equivalent beam sections.
OptiStruct Z and BOX sections are converted to ANSYS ASEC beam sections. CHAN, Z, and BOX sections are only converted when PBEAML has a HyperBeam section attached. PBEAM is converted to ANSYS ASEC when HyperBeam sections are not attached to a property card. OptiStruct NSM is converted to ANSYS ADDMAS.
Limitation: In the current version of the conversion tool, section offsets are not considered.
Note #2
PSHELL and PSHEAR properties are converted to ANSYS SECTIONS with type SHELL. Shell thickness and material from PSHELL/PSHEAR are mapped to TK and Material of SHELL section. After conversion, section offset is always set to MID.
Note #3
Conversion of contact surfaces: If contact surfaces in OptiStruct are defined with node sets, then the surfaces will not be converted.
See Also:
OptiStruct Conversion Tools
