Engineering Solutions
Project Points
Project Points
Project Points
Use this macro to project geometric points (such as weld points) to nearby edges. Clicking this button opens a surfs selector in the panel area; use this to select the surfaces whose edges you wish to project points to.
After selecting surfs and clicking proceed, a target element size field is displayed. Type a value into this field, using the same units as your model. Any points within this distance of the selected surfaces’ edges will be projected to those edges.
See Also:
Geom/Mesh Utility Menu
