Engineering Solutions
Auto Connectors Macro
Note:If you are unfamiliar with connector entities, refer to Connector Definition and Connector Realization for more information.
The Auto Connectors macro automates the importation and FE realization of connectors from either a Master Connectors File or an older Master Weld File. Virtually every option available for FE realization in the connectors module is also available in the Auto Connectors macro.
auto-conn-creation_11
Automated Connector Creation and FE Realization dialog
auto-conn-creation_expanded_11
Automated Connector Creation and FE Realization dialog - custom option
Input requirements for connector entity creation and FE realization are:
Master connectors/weld file
FE config
Projection tolerance
Note:In the case of a custom FE config, the custom FE type-to-realize is required.  The custom FE type definitions can be found in the appropriate feconfig.cfg file.  This script automatically reads the default feconfig.cfg file and displays a list of all the appropriate user-defined FE types (found in the feconfig.cfg file) in the Fe type field.
The property and diameter can be specified if necessary.
Additional options are:
Build systems
Snap to node
Attach to shells
See Also:
Geom/Mesh Utility Menu
