Engineering Solutions
Master Weld Files
Master Weld Files
Master Weld Files
The Master Weld File provides the weld location and parts to be connected. A format example is shown below.
PointId
1t/2t/3t
X
Y
Z
PartId1
PartId2
PartId3
12::
2::
2.25:
2.25::
1.0::
2::
3::
23::
3::
3.05::
3.25::
0.25::
2::
3::
5::
See Also:
Default Utility Menu
Geom/Mesh Utility Menu
Diameter vs. Thickness Files
