Aerospace offers the following functions in the Properties menu:
Create beam cross-section entities that you can use to simplify complex portions of your model into simple bar elements. |
Create, review and edit collectors and card images or dictionaries. |
Laminates are collections of Plies (or in some cases other laminates) that are considered to be fastened together into a single structure for purposes of simulation. |
Reorganize your database by copying or moving data (entities) among collectors or includes. |
Ply entities are used to represent layers in a laminated composite material, such as carbon fiber or fiberglass composites. |
Create property collectors, which can be used to assign physical properties to entities. |
Renumber entities. |
