Engineering Solutions
Properties Menu
Properties Menu
Properties Menu
NVH offers the following functions in the Properties menu:
HyperBeam
Create beam cross-section entities that you can use to simplify complex portions of your model into simple bar elements.
HyperLaminate
Create, review and edit collectors and card images or dictionaries.
Laminates
Laminates are collections of Plies (or in some cases other laminates) that are considered to be fastened together into a single structure for purposes of simulation.
Organize
Reorganize your database by copying or moving data (entities) among collectors or includes.
Plies
Ply entities are used to represent layers in a laminated composite material, such as carbon fiber or fiberglass composites.
Properties
Create property collectors, which can be used to assign physical properties to entities.
Renumber
Renumber entities.
