Engineering Solutions
RADIOSS to OptiStruct Conversion
Use the Conversion tool to convert a RADIOSS file to an OptiStruct file.
1.Load the RADIOSS user profile.
2.Import a RADIOSS model.
3.To run the Conversion macro, from the menu bar, click Tools > Convert > RADIOSS > To OptiStruct. The Conversion tab opens.
4.To start the conversion, click convert.
5.In the RadiossBlock to OptiStruct conversion tool dialog, click Yes to convert extended property and material cards to OptiStruct. For example PSHELLX, PSOLIDX, and MATXi. After the conversion, the OptiStruct user profile automatically loads.
Conversion Mapping
The conversion coverage for RADIOSS to OptiStruct is currently limited to the Elements, Properties and Materials described in the conversion mapping tables below.
Elements
RADIOSS type
OptiStruct type
BEAM
CBEAM
BRIC20
CHEXA
BRICK
CHEXA, CPENTA, CTETRA
PENTA6
CPENTA
SH3N
CTRIA3
SHELL
CQUAD4
SPRING + PROP/SPRING (TYPE 4)
CBUSH1D
SPRING
CBUSH
TETRA4
CTETRA
TRUSS
CROD
Properties
RADIOSS type
OptiStruct type
PROP/BEAM (TYPE 3)
PBEAM + PBEAMX*
PROP/SH_SANDW (TYPE11)
PCOMP**
PROP/SHELL (TYPE 1)
PSHELL + PSHELLX*
PROP/SOLID (TYPE 14)
PSOLID + PSOLIDX*
PROP/SPR_BEAM (TYPE 13)
PBUSH + PBUSHT
PROP/SPR_GENE (TYPE 8)
PBUSH + PBUSHT
PROP/SPR_PUL (TYPE 12)
PBUSH
PBUSH1D
PROP/TRUSS (TYPE 2)
PROD
*Only when you click Yes in the RadiossBlock to OptiStruct conversion tool dialog.
**Only material, ply thickness, and ply angle is converted.
Materials
RADIOSS type
OptiStruct type
MAT/COMPSH (LAW 25)
MAT9ORT**
MAT/ELAST (LAW 1)
MAT1
MAT/HONEYCOMB (LAW 28)
MAT9ORT + MATX28*
MAT/PLAS_JOHNS (LAW 2)
MAT1 + MATX02*
MAT/PLAS_TAB (LAW 36)
MAT1 + MATX36*
MAT/VOID (LAW 0)
MAT1 + MATX0*
**The values of NU23 and NU31 are set to default values on conversion.
See Also:
RADIOSS Conversion Tools
