Engineering Solutions
Morphing
Morphing
Morphing
HyperMorph is a tool used to morph the shape of a finite element model in ways that are useful, logical and intuitive.  It enables rapid shape changes on the FE mesh without severely sacrificing the mesh quality.  During the morphing process, HyperMorph also allows for the creation of shapes which can be used for subsequent design optimization studies.
Overview: The Three Basic Approaches to Morphing
The Domains and Handles Concept
The Morph Volume Concept
The Freehand Concept
Global Domain and Global Handles
Local Domains and Handles
Partitioning
Dependent Handles
Working with Shapes
Setting Up Optimization
Space Frame Model Strategies
Creating Handles and Domains
Matching a Mesh or Line or Surface Data
Making Parametric Changes
Controlling Global Morphing with Handle Placement
Mirror Images: Using 1-Plane Symmetry
Reducing 3D to 2D: Using Linear Symmetry
Reducing 3D to 1D: Using Planar Symmetry
Shell Model Strategies
Morphing on Local Domains
Morphing Global Handles
Using Constraints
Using Biasing
Solid Model Strategies
Viewing Solid Models
Using Constraints
Using Biasing
See Also:
HyperMorph Module
