The Results Initializer is a tool that allows you to quickly initialize the sheet metal components in the crash model with stamping history (strain, thickness) but staying within the Engineering Solution’s Crash pre-processing environment. HyperForm's One-Step solver capability is leveraged in this tool for estimation of the stamping history.
The Results Initializer provides the following features:
• | User interface to select the components in the model to be initialized with stamping history and define stamping parameters. |
• | Ability to conduct One-Step HyperForm analysis for selected components in a batch process. |
• | Review of the One-Step stamping results in the Crash user profile. |
• | View available options to saturate higher strains by prescribing cutoff value on max strain and do a rerun. |
• | Ability to repeat above sequence multiple times on same/different component. |
• | Strain history information from the One Step is attached to the model as an include file. |
• | Supported for both solvers RADIOSS and LS-DYNA. |
The Results Initializer is available in the Crash LS-DYNA and RADIOSS user profiles. It can be accessed by clicking the icon in the Crash toolbar or by clicking BCs > Results initializer from the menu bar.
Invoking the Results Initializer opens a Process Manager tab that guides you through the process seamlessly to initialize the parts with the stamping strain history.
A tab as shown below appears to manage the selection of components for initializing with stamping strains. The items in the tab perform the following actions:
The selected components appear in the Process Manager tab. Selecting the checkbox for TWB search will prompt the software to check for Tailor Welded Blanks (TWB) among the selected blanks. Clicking Proceed or Next moves you to the next step. |
This tab appears only if the TWB search option is activated in the previous step. A tab as shown below appears to allow you to edit the parts that are automatically detected as part of the TWB search. Right-clicking the TWB crash parts provides an option to edit TWBs, which will result in a tab, as shown below.
A tab as shown below appears to allow you to fill the holes in the parts before initializing them in the real stamping process.
The next tab lists the selected components and their assigned material and its thicknesses. The last column allows you to assign the Blank Holding Force for each component. None, Low, Medium, High, Crashform, Optimum-FLC and Optimum-EPS are seven options available to choose for Blank Holding Force. The default is Optimum-FLC.
Click Initialize to launch the results initialization process. The process involves four steps:
During this process, the Engineering Solutions session is live. Messages are continuously posted to update you with the status of the initialization process. At the end of this stage, the file that has the result for each selected component are attached as an include file to the model. |
A tab as shown below appears that lists available result types and components that were initialized for review. At any time, only one component can be selected for reviewing the results. In addition to the selected components, there will be a component with the name All that contains the results of all the components for easy review. Legend threshold optionThe Legend Threshold option allows you to set the maximum and minimum threshold value of the results legend and accordingly contour the results. Click Review to contour the selected result type in the graphics area and open the Contour panel to adjust the legend and switch to other results. |
This stage is a correction step that you can bypass if it is not required. Depending on the component’s topology, some of the selected components could show very high strains. It is quite normal in real process as the component is formed by building an addendum that enhances material flow. Also, it would be stamped in more than one stages. Hence, in this step, you can select these components and apply a cutoff on the components maximum plastic strain and rerun the initializing analysis. This will limit the maximum strain after analysis to the cutoff value. Click Initialize to rerun the analysis with the cutoff value for the selected components, as explained in the solve and initialize phase. The results from this rerun for the selected components will overwrite the results from the earlier run. |
This phase is similar to the earlier review phase; it allows you to review the results after applying cutoff. This step can be bypassed if phase four is bypassed. |
Batch Results Initializer is a tool that can initialize the sheet metal components in the FE model with one step stamping results in batch mode. Currently it is available for the solver decks of RADIOSS and LS-DYNA. The Batch Results Initializer can be invoked using the executable LAUNCHRIGUI.bat/.sh for Windows and Linux, respectively. The GUI appears as follows: The options are as follows: Solver: This is a destination solver of the CAE analysis. Currently LS-DYNA and RADIOSS are supported. Based on the choice of the solver some of the options change. File Selection: Input deck: The solver deck that has components/ assemblies that need to be initialized with stamping results. Input entity file: The initialize.dat file that has the components that need to be initialized with stamping results. This is a text file with four columns with space as a delimiter.
One-Step Solver Options: Entity type: You can choose Part for LS-DYNA and Part and Subset for RADIOSS. These settings will be used if column 3 in the initialize.dat file is blank/undefined. Blank Holder Force: You can choose one of the following: Crash-form, None, Low, Medium, High, Optimum-FLC or Optimum-EPS. These settings will be used if column 4 in the initialize.dat file is blank/undefined. Plastic strain cutoff: This is the max strain value beyond which strain from stamping will be saturated to this value. The value is provided in percentage. For example, a strain value of 0.2 should be provided as 20. TWB (Tailor Welded Blank) search: If this is turned on, a search is performed within components selected for Results Initializer to have potential TWBs. The TWB components are then subjected to one step stamping analysis together. Fill holes: If turned on, the holes on the component are filled and then subjected to one step stamping analysis together. Hole fill size: This field is available only if the Fill holes option is turned on. Provide the maximum size (perimeter) of the hole that needs to be filled before one step stamping analysis. No. of cores: You can define the number of cores available in your computer. By default it will use all the cores in your computer. Generate .res: If turned on, a res file that has the results of all the components chosen for Results Initializer will be created at the end of run. Result File Options: These options are self explanatory. Input files
Output files
Batch Results Initializer and Nesting is a tool that can initialize the sheet metal components in the FE model with one step stamping results and/or do nesting of the blanks from one step stamping results for material utilization in batch mode. Currently it is available for CAD files in the format supported by HyperMesh and the solver decks of RADIOSS, LS-DYNA, OptiStruct and Nastran. The Batch Results Initializer and Nesting tool can be invoked using the executable LAUNCHRINESTINGGUI.bat/.sh for Windows and Linux, respectively. The options are as follows: Application: Select either Results Initialization and/or Nesting by activating the checkboxes. Based on your selection some of the options will be turned off. Input file type: Select either CAD or HM for the input file types for the parts. All CAD formats supported by HyperMesh are supported here. Solver: This is a destination solver of the CAE analysis. Currently OptiStruct, Nastran, LS-DYNA, RADIOSS and Abaqus are supported. Based on the solver you select the material database needs to be selected. The material needs to be HyperForm One-Step format for Optistruct, Nastran and Abaqus. The material needs to be in the corresponding solver format for LS-DYNA and RADIOSS. File Selection Parameter file: This is the path of the .csv file that has the following columns with a comma as a delimiter.
Material file path: This is the path where the material library is located that is referred to in the .csv file. One-Step Solver Options: Blank Holder Force: You can select one of the following: Crash-Form, None, Low, Medium, High, Optimum-FLC or Optimum-EPS. These settings will be used if column 4 in the initialize.dat file is blank/undefined. Fill holes: If this checkbox is activated the holes on the component are filled and are then subjected to one step stamping analysis together. Max. perimeter: This field is available only if the Fill holes option is activated. Provide the maximum size (perimeter) of the hole that needs to be filled before one step stamping analysis. No. of cores: You can define the number of cores available in your computer. By default all of the cores in your computer will be used. Results Initializer Options: Plastic strain cutoff: This is the max strain value beyond which strain from stamping will be saturated to this value. The value is provided in percentage. For example, a strain value of 0.2 should be provided as 20. Nesting Options: Type: Select Sheet or Coil. Pattern: Activate the checkbox for One up, Two up or Two up–Mirror. Addendum: Uniform addendum value all around the blank for nesting. Part to Part margin: Part to part margin/gap for nesting. Part to Edge margin: Part to edge margin/gap for nesting. Carrier: If this checkbox is activated select from the carrier types Single sided (ss), Double sided (ds), Nested (n), Central (c), Double sided and Nested (ds&n), Double sided or central (ds&c). Carrier Height: Height of the carrier. Part to Carrier margin: Distance between the part edge and the carrier. |
