Engineering Solutions
Safety Menu
Safety Menu
Safety Menu
The Safety menu lists options for crash safety modeling such as airbags, seatbelt and dummy positioning. The menu has minor modifications depending on the solver that is loaded.
radioss_crash_safety_menu
lsdyna_crash_safety_menu
safety_menu_pam
RADIOSS
LS-DYNA
PAM-CRASH
Airbags
Create, edit and review airbags.
Seat Mechanism
Opens the Mechanism browser to create and articulate a kinematic mechanism.
Dummy Positioner
Opens the Dummy browser to position a dummy model.
Occupant
Shortcut to the Dummy Positioning panel for dummy articulation and positioning.
Sensor
Opens the Create sensors dialog.
Seat Belts
Shortcut to the Seatbelt panel for routing seatbelts around the dummy.
Retractor
Create, edit and review retractors on nodes through the Mass panel with elem types set to RETRACTOR.
Pretensioner
Create, edit and review retractors on nodes through the Mass panel with elem types set to PRETENSION. (LS-DYNA only)
Sliprings
Create, edit and review sliprings on nodes through the Mass panel with elem types set to SLIPRING.
FMVSS 201/ECE-R21
Opens a Process Manager tab. This tool generates a deck for the simulation of the head impact on an instrument panel. It is available in the RADIOSS and LS-DYNA user profiles.
Pedestrian Impact
Opens a Process Manager tab. This tool generates an input deck for the simulating pedestrian head and leg impacts on vehicle hoods, windshields, bumper and bonnets. The Pedestrian Impact tool is available in the RADIOSS and LS-DYNA user profiles.
See Also:
Crash Application
CRASH-2300: Creating a Seat Mechanism Using the Mechanism Browser
