Engineering Solutions
Setting Global Parameters
The Global panel, accessed only by pressing G on the keyboard, controls model parameters that are accessed by several different panels. These parameters remain constant until changed.
Use this panel or the template subpanel on the Files panel to specify the template file you want to use.
The Global panel controls which components or collectors are active; any entities created are stored in the active collectors.
Elements are designated as first order elements by default. If you want to create second order elements, click the toggle after element order to second.
See Also:
Menu Bar
Setting Tolerances
