The Visualization Controls tab allows you to change many of the visual states. This is accessed from the Visualization toolbar, using this icon
There are nine different types of visualization controls: Connectors, Constraints, Equations, Loads, Morphing, Systems, Tags, Topology and Vectors. Many of these options previously existed in several different panels but now are easily accessible in one location.
Option
Connector size
Color by
Controls how connectors are color-coded in the graphics area. The colors for these options cannot be changed, but each radio button activates a separate color by scheme: State, Layer, Style or Component.
Schemes and their corresponding color items include:
• | State – Realized, Unrealized and Failed |
• | Layer - < 2t, 2t, 3t, > 3t |
• | Style – Apply mass, area, bolt, seam, spot |
• | Component - Connectors are colored based on the color of the component they exist in. |
State/Layer/Style
Option
Constraint labels
Shows or hides the labels on constraint entities.
Constraint size
Controls the display size (in model units) of constraint entities in the graphics area.
Option
Equation handles
Option
Template labels (type)
Load labels
Shows or hides labels on load entities (forces, moments, pressures, accelerations, velocities, temperatures, fluxes).
Load size
Controls the display size (in model units) of load entities in the graphics area. This includes options for Magnitude % (which uses the magnitude of the load to determine the size) and Uniform, which applies a constant size.
Option
Handle size
Symmetry size
Colors
Morph volume edges, Edge points
Morph volume faces
• | Wireframe means that the face has no color at all; only the morph volume edges and handles are drawn. |
• | Transparent (one, two, or three) means that the faces are drawn semi-opaque; higher numbers mean more opacity. |
• | Opaque sets the morph volumes’ transparency to zero. |
Option
System size
Option
Push tags to foreground
Tag text
Tag icon
Option
Show line directions
Option to show/hide graphics on line entities, indicating the direction of the line.
Edges/Shaded faces on solids
Controls both the color-coding of the respective entities in the graphics area and the display of those entities that match the selected criteria. Changes to the color options only apply when used within the relevant geometry shading and color modes.
Solid transparency
Controls the level of transparency for solid entities when used within the relevant geometry shading and color modes. Higher numbers mean more transparency.
Mappable solids
Controls the color-coding of mappable solids when used with the relevant geometry shading and color modes.
Option
Vector labels
Option to show/hide labels on vector entities.
Vector size
Controls the display size (in model units) of vector entities in the graphics area. There are options for Magnitude % (which uses the magnitude of the vector to determine the size) and Uniform, which applies a constant size.
Vector handles
Option to show/hide handles on vector entities.
