• | Editable cells have a white background, unless it is the active cell. You can input values using the keyboard in editable cells. Non-editable cells have a gray background. |
• | Left-click in an editable (white background) cell to activate it for input. Click in an active cell to move the insertion cursor to the character nearest the mouse. |
• | Press CTRL and the left or right arrow key to move the cursor within the active cell. Use the left, right, up, and down arrows to change the active cell. |
• | Press BACKSPACE to delete the character before the insertion cursor in the active cell. |
• | Press DELETE to delete the character after the insertion cursor in the active cell. |
• | Table columns can be resized by positioning the cursor along a column border, pressing the left or right mouse button, and dragging the border to a new position. |
• | In some fields, you can use the (…) button to open the Entity browser to select the entity for that field. |
