1. | Use the Element Set selector to specify the elements containing the nodes that define the cross-section. |
The Set Browser can be used to create the necessary element sets.
If multiple element sets are selected, each set is added to the table as a separate cross-section definition which can be modified later by selection.
2. | Use the Node Set selector to define the nodes in each currently selected element set at which grid point data will be extracted and summed from. |
Only the nodes contained within the selected node set will be part of the grid point extraction. Use the Set Browser to create the necessary node sets.
If multiple node sets are selected for a single element set, HyperMesh adds separate cross-section definitions to the table with the original element set and each selected node set.
3. | Use the Summation Node selector to define the node about which the grid point data will be summed. |
If no node is selected, the utility defaults to "Centroid". This option calculates the nodal averaged centroid of the coordinates of all of the nodes in the node set and creates a temporary node at that location.
When using the "Centroid" option, a temporary node is created. If this node is deleted from the model, the loads associated with that node are also deleted.
4. | Use the Result System selector to define the coordinate system into which the grid point vector results will be transformed and output. |
If a results system is not specified, the Engineering Solutions "base" system is used by default.
5. | The Display sections checkbox is a graphical review option that, when checked, displays the element set, node set, result system and summation node which define the cross-section in the graphics display area. |
6. | Optional: activate the Show model checkbox. |
This displays the entire model in transparency mode, highlighting the currently selected element set, node set, result system and summation node. This allows you to verify a cross-section definition.
7. | Optional: use the filter buttons on the top of the spreadsheet to select which cross-sections are required. |
Standard Ctrl/Shift–click functionality can be used to select cross-sections. Selected cross-sections can also be deleted from the database by using the Remove selection button on the right end of the filter buttons.
Each time a cross-section is created, modified, or deleted, the cross-section data is saved to the database. When the database is saved, all cross-section definitions are also saved. Therefore, cross-section definitions only need to be defined once and stored in the database. Cross-Sections can then be accessed from within the Resultant Force and Moment utility, which utilizes the cross-section definitions to perform these calculations.
Renumbering element or node sets after running the tool invalidates the link between the cross-section names and the associated sets. Therefore, it is important to avoid renumbering any element or node sets for which cross-sections are to be retained within the database.
