Engineering Solutions
Rename Entities
Rename Entities
Rename Entities
1.Right- or left-click an entity (lowest level in tree hierarchy) in the Laminate Browser tree to select it.
2.Right-click the selected entity.
A context-sensitive menu appears with three options: Rename, Duplicate, and Delete.
3.Click Rename.
The name of the selected entity in the Laminate Browser switches to a text box.
4.Enter the desired new name in the text box.
You can also rename an entity by altering the relevant field in the Define/Edit pane and then clicking Apply or Update Laminate.
