Engineering Solutions
Review and Update Entities
1.Right-or left-click an entity (lowest level in tree hierarchy) in the Laminate Browser tree to select it.
The selected entity is highlighted.
The Define/Edit and Review/Results panes are populated with details of that entity.
2.Make the desired changes to the entity definition in the Define/Edit pane and click Apply or Update Laminate to update the entity.
