Introduction to HyperWorks
Altair HyperWorks Licensing
In HyperWorks 2017, the underlying licensing technology is LM-X.  This update changes how many license features each application requires.  The current conversion formula for HyperWorks Units to HyperWorks features (what is actually in the license file) is now 1 to 1000.  Previously, 1 HyperWorks Unit was 100 GridWorks features.  For each HyperWorks Unit (HWU) purchased, there are 1000 HyperWorks features available in the license file.  This should not be confused with products that are licensed as product feature based.  Unit based applications draw HyperWorks features, and feature based product licenses draw their respectively named feature from the license file (such as HyperShapeCatia).
The HyperWorks licensing system has been designed to allow HyperWorks Partner Products (selected third party products) to be licensed via HyperWorks units.  As part of the license agreements to enable partner software, product usage data must be sent to Altair.  The Altair HyperWorks license package is separate from the HyperWorks application package and contains both the Altair License Manager and Usage Report Tools (URT).
HyperWorks applications use two types of licensing: HyperWorks Units Licenses and HyperWorks Feature Licenses.  A more complete description of each licensing type follows.
HyperWorks Units Licensing
HyperWorks Unit licenses allow any of the HyperWorks applications to run, as long as there are sufficient HyperWorks license features available. One HyperWorks Unit (HWU) consumes 1000 HyperWorks license features.
HyperWorks unit licensing has the following characteristics:
•Must use a license server (as opposed to Nodelocked licenses)
•Enforces Global Licensing (see Global Licensing)
•Provides the advantage of the Altair units based business model (leveling/stacking/decaying of units, see below)
•Leveling and stacking is not confined by the number of machine cores.
•License decay function for massive use of RADIOSS finite element solver for simulation driven innovation
•Multiphysics and co-simulation licensing, which determines the license draw just based on the number of cores that are used, and effectively lowers the cost.
The license server tracks and records the total quantity of units the customer purchased and how many of those units are currently being used by each user.  The license server provides real time status (via lmxendutil –licstat) and transaction based logging of all license usage.  Refer to the Altair License Manager documentation for more details.
The Altair Business Model:  Leveling and Stacking
By implementing leveling, customers can use multiple applications from the HyperWorks suite at the same time without incurring additional license usage.  Many of the HyperWorks suite applications level with each other.  This leveling is based on the application running on the same host and username.  For most applications, the actual cost of running multiple applications on the same host/username is simply the cost of the most expensive application running.  The lower cost applications simply run at no additional license cost.  For example, if a user starts HyperMesh (cost of 21 HWU) and then starts an instance of HyperGraph (cost of 6 HWU), that user will only be using 21000 HyperWorks features from the license server.  The same goes for multiple instances of the same application.  For example, a user can open multiple instances of HyperMesh, and still only draw 21000 features.
Applications that stack always draw the associated number of units, regardless of any other applications or concurrent usage on the user/host.
Solvers such as OptiStruct and RADIOSS, that run under the same user and host, level or stack the license by the following rules:
•At the first invoke of a batch application, the HyperWorks units level against the existing HyperWorks applications.
•Similarly, at the first invoke of a different batch application, the HyperWorks units still level.
•The HyperWorks units stack when starting the second and so forth invoke of the same batch application.
•When the leveled run finishes, the next invoke levels again.
For example, on a single core machine, if the user launches HyperMesh first (21 HWU), and then launches a MotionSolve job (25 HWU), 25 HWU will be drawn from the license manager.  If the same user, under the same host, adds an OptiStruct run (50 HWU), the total units drawn from the license server is 50 HWU.  If the user now adds a second OptiStruct run, the total units drawn increases from 50 HWU to 95 HWU (50 plus 50 HWU minus 5 HWU for license decay on the second instance. See Solver Unit Draw below).
Data Manager stacks four HyperWorks units with every instance.
The number of HyperWorks units drawn by RADIOSS depends on the number of machine CPU-cores used per run.
Feature-based Product Licensing
Feature based product licensing allows a particular application to run as long as the feature name is available in the license file and the server has not reached the number of available features checked out.  Think of this model as the more familiar seat based type; there is a set number of seats or copies allowed at any given time.  Feature based product licensing does not require or checkout HyperWorks license features.  However, it does require a checkout of 1 GlobalZone feature of the appropriate time zone (see Global Licensing).
See Also:
Altair HyperWorks 2017 Product Licensing Unit
Project Tracking
Connecting to the Altair License Manager
Global Licensing
Hosted HyperWorks Units (HHWU)
