Introduction to HyperWorks
Using the Search Function
The Search function allows you to search the entire help system to locate information beyond predetermined index entries.  It locates every occurrence of a specified word or phrase.
To locate a topic using Search:
1.In the left frame of the browser, select the Search tab.
2.Select your search criteria options.
•Under Category:, select the product(s) to search. The default is set to All. It does not matter which (if any) product application is open; you can select any available item in the list. You can select as many options as you would like.
select_product_menu_14
3.Enter the search string in the field and click Submit.
A list of topics that contain the searched word or phrase will be displayed in the left frame, along with the number of times the match is found.
4.To view a topic listed in the results, click the topic name.
The terms that match your search will be highlighted in yellow in the topic text.
See Also:
Using HyperWorks Help
Using the Browser Find Function
