Manufacturing Solutions
Spin panel
Spin panel
Previous topic Next topic Expand/collapse all hidden text
Spin panel
User Profiles:
Incremental_LS-DYNA
Die Module
Use the Spin panel to create a surface and/or mesh or elements by spinning a series of nodes, a line or lines, or a group of elements about a vector to create a circular structure.
Examples
Spin nodes to create a surface
HM_Panels_bmp00303
Nodes are selected.
HM_Panels_bmp00304
The base node is selected.
HM_Panels_bmp00305
The surface is created.
Spin lines to create a surface
HM_Panels_bmp00306
Nodes are selected.
HM_Panels_bmp00307
The base point is selected.
HM_Panels_bmp00308
Spin elements to create a surface
HM_Panels_bmp00309
Elements are selected.
HM_Panels_bmp00313
HM_Panels_bmp00311
Spin a group of elements to create a surface
HM_Panels_bmp00312
HM_Panels_bmp00310
HM_Panels_bmp00314
The elements in this illustration were created by using spin +, with a negative biasing value.
HM_Panels_bmp00315
The elements in this illustration were created without element biasing.
Subpanels and Inputs
The Spin panel contains the following subpanels and command buttons:
hmtoggle_arrow1Spin Geoms
Use the Spin Geoms subpanel to create a surface and/or mesh or elements by spinning a series of nodes, a line, or lines about the normal of a user-defined plane.
Panel Inputs
Input
Action
node list / lines selector
Pick the nodes/lines you want to spin.
N1, N2, N3, B
Specify a plane.
The selected nodes are spun about the normal of the plane.
angle
The angle through which to spin the nodes.
meshing options
•mesh, keep surf: creates a surface from the selected entities and then generates a mesh on the created surface.  The created surface is retained along with the mesh.
•mesh, dele surf: creates a surface from the selected entities and then generates a mesh on the created surface.  The created surface is then deleted and only the corresponding mesh is retained.
•mesh w/o surf: This option creates a mesh between the selected entities using linear interpolation without creating a surface.
•surface only: creates a surface from selected entities, but does not create a mesh.  You can use the resulting surface to perform any desired geometry cleanup functions or automeshing.
hmtoggle_arrow1Spin Elems
Use the Spin Elems subpanel to create a surface and/or mesh or elements by spinning a group of elements about the normal of a user-defined plane.
Panel Inputs
Input
Action
elems selector
Pick the elements you want to spin.
N1, N2, N3, B
Specify a plane.
The elements are spun about the normal of the plane.
angle
The angle through which to spin the elements.
on spin
Enter the number of elements you want to generate along the path of the spin.
bias style
Select linear, exponential or bellcuve
bias intensity
hmtoggle_arrow1Command Buttons
The following action buttons appear throughout the subpanels:
Input
Action
spin +
Creates the surfaces in the direction specified.
spin -
Creates the surfaces in the opposite direction
reject
Reverts the most recent changes.
return
Exits the panel.
How do I...
Spin elements
Spin elements to create elements with a user-specified bias
See also
An Alphabetical List of Panels
HM-3210: Creating a Hex-Penta Mesh using Surfaces
