Acoustic Cavity meshing generates a fluid volume mesh used to calculate the acoustic modes (or standing waves) inside the air spaces of a vehicle or similarly enclosed structural model. This is primarily used by Noise, Vibration, and Handling (NVH) engineers to design quieter interiors.
Acoustic Cavity meshing begins with the Acoustic Cavity Mesh panel. This panel accepts the necessary base input data to generate a voxelated preview mesh for one or more acoustic cavities. Once the preview mesh exists, however, the Acoustic Cavity tab displays in the tab area; you can use this tool to modify element quality checks, select specific volumes that have a preview mesh, and create the computational mesh for each selected cavity.
Acoustic cavity meshing can be a CPU-intensive process, especially with fine and/or complex meshes, but this can be offset by additional CPU cores. The Acoustic Cavity Mesher is multithreaded to take advantage of multi-core environments.
Hole and gap patching is a critical part of defining cavities enclosed in the structure model. The process refers to patching over inconsequential gaps and holes that inevitably exist in the structure model, such as speaker holes.
Gaps are defined as elongated openings based on their longest dimensions. Holes are openings defined by the radius of a sphere that can pass through them. By specifying the size of the hole and gap patches, you can control how the cavities are defined through auto search.
Typically, a cavity model is intended to be meshed right up to the outer body panel. Plastic and fiber trim panels are often included in a trimmed body model, but not meant to be used for cavity meshing. However, if the trim panels are selected during the AC meshing process they can be confused as outer body panels, leading to incorrect cavity definition. Therefore, it is important to ensure that only the exterior body panels are selected as the structure components to be included in the auto cavity search.
Some typical types of cavities that you may wish to model include:
• | Door cavity: most users prefer to include the cavity between the inner and outer door panels as a part of the interior. To make this happen, you must specify a hole patch size smaller than that of the largest opening in the inner panel, so that the opening is not patched. This allows interior mesh to flow into the door cavity. |
• | Instrument Panel (IP) cavity: to model the cavity behind the Instrument Panel as a part of the interior cavity, you must exclude the IP parts from the structure component selection during auto cavity search. This forces the auto cavity search to ignore the existence of the sealed IP cluster when determining the interior volume of the passenger compartment. If the IP panel needs to be treated as a radiating source, a fluid boundary needs to be created at the location of the IP, similar to the how a package tray can be included as a structure part. |
• | Pillar Cavity: To included large pillar cavities (such as a D pillar cavity) as a part of the interior cavity, you must ensure that the gap and hole patch size specified are smaller than that of the largest opening. This prevents the opening from being patched and allows interior mesh to flow into the pillar cavity. |
• | Under seat cavity: To ensure the under-seat spaces are meshed, you must specify an element size smaller than the smallest dimension of the space, thus allowing the interior mesh to fill the cavity. |
• | Trim component cavity: special functionalities are required to mesh these cavities. |
The ability to model the acoustic cavity and predict acoustic response inside it is a critical part of NVH analysis, as noise level and quality become key product quality differentiators in the marketplace. A number of factors need to be considered when meshing an acoustic cavity model:
• | Adequate Mesh Size. A rule of thumb is that at least six elements are needed per acoustic wavelength. Based on this rule, the minimum acoustic element sizes at various frequencies are: |
500 Hz: |
114 mm |
1000 Hz: |
57 mm |
Smaller elements mean a more complex cavity model, which takes longer to run and generates a larger output file--particularly when fluid grid participation output is requested. Recall, however, that the mesher is multithreaded to take advantage of multiple CPU cores.
Mesh size can also affect whether smaller cavity areas, such as the cavities underneath seats, get filled. Mesh size should be selected by considering the size of the smallest cavity that needs to be filled.
• | Mesh quality as defined by Jacobian value, Tetra Collapse, and similar measures. Poor mesh quality may cause problems when submitted to the solver, or lead to less-accurate results. |
• | How closely the cavity shape matches the actual structure. This impacts how accurately the cavity model captures acoustic modes, and how difficult it is to obtain good coupling between the fluid and structure. It is important to define the structure panels intended to be coupled to the cavity. |
• | Aesthetics of the Cavity Mesh. The model may appear too jagged if the cavity mesh matches the structure closely. Some users prefer a smooth looking mesh for presentation purposes, but care must be taken so that this does not adversely affect the modes calculated or the quality of coupling generated when default ACMODL search parameters are used. |
• | Interior Response definition. Interior response points need to be defined so that they become a part of the mesh definition when cavity mesh is generated. |
• | Seat Foam Cavity definition and coupling. Seat foams are typically modeled as denser air cavities. Their geometry definition can come in either as CAD data or existing FE mesh. Some seat models contain detailed foam curvature definition, while others may just be blocky boxes. The acoustic mesher can generate a new seat foam mesh and use congruent grids to connect to the interior cavity elements, or generate fluid MPCs to connect grids on a existing foam cavity mesh to the interior cavity mesh. |
• | Trunk Cavity separated from the Interior Cavity. For passenger sedans, the trunk cavity is typically modeled as a separate cavity from the interior, separated by the rear seat back foam cavity. |
• | Package Tray properly coupled to both interior and trunk cavities. For passenger sedans, the "package tray" or "parcel shelf" is situated behind the rear seat backs, between the interior cavity on the top and the trunk cavity below. Its vibration should be coupled into both cavities. This means a boundary (or gap) needs to exist in the cavity model where the package tray is located. This is typically accomplished by the two cavities not sharing grids at the boundary. |
Once generated, fluid cavities must be coupled to the structure. OptiStruct creates this coupling automatically during solver analysis, storing the information in the ACMODL card. In addition, RADIOSS generates an .interface file which can be loaded into Engineering Solutions to verify fluid surface and structure wetted surfaces:
