Engineering Solutions
Volume Meshing
Volume Meshing
Volume Meshing
Volume mesh or "solid meshing" uses three dimensional elements to represent fully 3D objects, such as solid parts or sheets of material that have enough thickness and surface variety that solid meshing makes more sense than 2D shell meshing.
Engineering Solutions builds 4- and 10-noded tetras, 6- and 15-noded pentas, and 8- and 20-noded hexa elements.  Tetras can be built in the Edit Element panel by hand or by using the Tetramesh panel.  Pentas and hexas can be built in any of the following panels:
Drag
Drags a group of two dimensional elements along a vector to create solids.
Edit Element
Builds elements by hand.
Line Drag
Drags a group of two dimensional elements along a line.
Linear Solid
Creates solid elements between two dimensional elements.
Solid Map
Builds solid elements between nodes, lines, and surfaces.
Solid Mesh
Builds solid elements between a variable number of lines.
Elem Offset
Creates solid elements by offsetting a group of two dimensional elements normal to the surface formed by the group of two dimensional elements
Spin
Spins a group of two dimensional elements about a vector to create solids.
Split
Propagates split hexas.
Tetramesh
Fills with tetra elements a volume that is enclosed by tria elements or surfaces.
Note:By default, first order linear elements are generated when the functions in these panels are executed, but second order parabolic elements may be generated by changing the element order in the mesh subpanel of the Options panel.
See Also:
Partitioning Solids for Mappability
Meshing
