Engineering Solutions
Auto Contact Browser
The Auto Contact browser provides options for viewing and modifying the contact pairs identified in the Auto Contact process. It contains the following columns:
Name
Lists the name of the interfaces, surfaces and surface interactions that were assigned.
Underneath the interface name are the temporary surfaces included in that interface. Red indicates a slave surface, and blue indicates a master surface.
Accept
When the Accept box is checked, the Interface will be included in the creation process.
Color
Color assigned to the interaction and surfaces
ET Type
ET Type
Real Set
Mat
Material assigned
The Auto Contact browser contains the following icons:
Options icon
auto_contact_options_icon
This opens the Options dialog.
ansys_auto_contact_options
Enter a new feature angle or customize the transparency for a selected entity. Click OK when finished.
Highlight Elements icon
auto_contact_highlight_elems_icon
Highlights the elements stored in selected entities in the graphics window. You can use the CTRL and Shift key to select multiple items in the table.
Review Elements icon
auto_contact_review_elems_icon
Review of elements stored in the selected entities. Elements are highlighted by color; all other components are grayed out. You can use the CTRL and Shift key to select multiple items in the table.
Review and Highlight are mutually exclusive. It is also possible to switch both options off. This is helpful when working with big models.
Fit View to Elements icon
FitModel_button
Automatically zooms in to the elements stored in the currently selected items.
Display All Elements icon
display_comps_with_elems_icon
In combination with the Highlight Elements or the Review Elements option, current contents remain unchanged on the screen.
Display Components with Elements icon
Highlights or reviews the elements referred by an interaction or surfaces and shows the components they belong to. All other components will be masked.
Display Only Elements icon
display_only_elems_icon
Only elements are highlighted or reviewed. The rest of the component and other components will be masked.
Select Elements Manually icon
select_elems_manually_icon
Opens the Element selection panel so that individual elements can be added/removed manually. Click proceed when finished.
Add by Adjacent icon
add_by_adjacent_icon
Adds the elements adjacent to the surface to the selected surface.
Right-click to undo one time.
Add by Face icon
add_by_face
Adds the adjacent face to the selected surface.
Recheck icon
recheck_icon
Opens the Auto Contact dialog to recheck the select interfaces. Recheck will either add more contacts to the existing contacts for modify the existing ones.
You can select interfaces from the browser, and the GUI will automatically populate the components that the interaction was based on. This helps modify an existing interface.
