Aerospace offers the following functions in the Collectors menu:
Create and modify assemblies, which are collections of component and multibody collectors or other assemblies. |
Create and update components. |
Load collectors contain the loads applied to entities, such as pressures, fluxes or forces. |
Vector collectors contain vectors which can then be used to define loads or transformations. |
System collectors contain coordinate systems, which can then be applied to different components of a model. |
BeamSection Collectors contain beam section data. |
Multibodies are jointed bodies made up of multiple parts and are often used to simulate crash test dummies and similar objects during crash analysis. |
Reorganize your database by copying or moving data (entities) among collectors or includes. |
Change the name of a specific collector or to rename types of collectors to their respective ID with an optional prefix. |
Renumber entities. |
Change the order of named entities in database. |
Change the color attributes of a collector. |
