Engineering Solutions
Contact Surfaces entityContactSurfaces-24
Previous topic Next topic Expand/collapse all hidden text
Contact surface entities are used to define and store contact definitions typically used in contact analysis.  Contact surfaces are defined using elements (1D/2D/3D) and their respective facecodes.  A contact surface is displayed as an arrow on the selected element faces.  The direction of the arrow is along the element normal that defines the contact surface.  Contact surfaces are shown under the ContactSurface folder within the Model browser.
Contact surfaces have a display state, on or off, which controls the display of a contact surface in the graphics area.  The display state of a contact surface can be controlled using the icon next to the contract surface entity in the Model browser.
Contact surfaces also have an active and export state.  The active state of a contact surface controls the display state of the contact surface and the listing of the contact surface in the Model browser and any of its views.  If a contact surface entity is active, then its display state is available to be turned on or off and it is listed in the Model browser and any of its views.  If a contact surface entity is inactive, then its display state is turned off permanently and it is not listed in the Model browser or any of its views.  If a find operation "finds" an inactive contact surface entity, that contact surface entity will automatically be set to active.
The export state of a contact surface entity controls whether or not that contact surface is exported when the custom export option is utilized.  The all export option is not affected by the export state of a contact surface.  The active and export states of contact surface entities can be controlled using the Entity State browser.
The following panels can be used to create and edit contact surfaces:
Contactsurfs
Solver Card Support for Contact Surfaces
hmtoggle_arrow1RADIOSS
Supported Card
Solver Description
Supported Parameters
Notes
/LINE/SEG/
Definition of the line - segments
/SURF/SEG/
Describes the surface definition - segments
hmtoggle_arrow1OptiStruct
Master Slave contact is represented using contact surfaces.
Supported Card
Solver Description
Notes
ELIST
Damp Shell Elements for a Fluid Volume
SURF
Defines a surface used in a contact definition.
Defined using the Contact Surfs panel
hmtoggle_arrow1LS-DYNA
Supported Card
Solver Description
Notes
*SET_SEGMENT
Definition segements on element faces.
See Also:
Model browser
Entities & Solver Interfaces
Model Setup
