Engineering Solutions
Control Volumes entityControlVolumes-24
Previous topic Next topic Expand/collapse all hidden text
Control volume entities are used to define and store control volumes typically used in safety analysis.  Control volumes are shown under the ControlVolume folder within the Model browser.
Control volumes do not have a display state.
Control volumes have an active and export state.  The active state of a control volume controls the listing of the control volume in the Model browser and any of its views.  If a control volume entity is active, then it is listed in the Model browser and any of its views.  If a control volume entity is inactive, then it is not listed in the Model browser or any of its views.
The export state of a control volume entity controls whether or not that control volume is exported when the custom export option is utilized.  The all export option is not affected by the export state of a control volume.  The active and export states of control volume entities can be controlled using the Entity State browser.
The data names associated with control volumes can be found in the data names section of the HyperMesh Reference Guide.
The following panels can be used to create and edit control volumes:
Control Vol
Solver Card Support for Control Volumes
hmtoggle_arrow1RADIOSS
Supported Card
Solver Description
Supported Parameters
Notes
/MONVOL
Describes the monitored volume types
/MONVOL/AIRBAG1
Defines the airbag using standard gas
SelectsurfBox
/MONVOL/AREA
Describes the monitored volume type AREA.
SelectsurfBox
/MONVOL/COMMU1
Describes multi-chambered airbag with hybrid input of injected gas.
/MONOVOL/FVMBAG1
Describes Finite Volume Method Airbag.
/MONVOL/GAS
Describes the perfect gas monitored volume type.
SelectsurfBox
/MONVOL/PRES
Describes the pressure load curve monitored volume type.
SelectsurfBox
REFSTA
Describes the reference state (stress free state) of elements
You need to create a new include file, set the include file type as REFSTA and create this card in the include file.
hmtoggle_arrow1LS-DYNA
Entities can be created using the Solver browser. All the supported LS-DYNA keywords appear in the tree view in the Solver browser, sorted by type of input data. To display the Solver browser, select Solver Browser from the View menu.
The complete list of LS-DYNA keywords that are supported are listed below.
An alternate way to identify a supported card is to invoke the "create new keyword" tool. This convenient selection tool can be invoked using the context menu in the Solver browser, using the Create New option in the Tools menu bar.
Once you select a card of interest, the right panel is opened with the necessary options set.
Use the Control Volume panel to control volume objects within a model. The *AIRBAG_OPTION card is output from this panel.  The POP option is supported for WANG_NEFSKE options.
The following keywords are supported:
Supported Card
Solver Description
Notes
*AIRBAG_ADIABATIC_GAS
_MODEL_ID
Define an airbag or control volume
Title
SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, PSF, LCID, GAMMA, P0, PE, RO
ControlVolHelp
*AIRBAG_ADVANCED_
ALE
*DEFINE_ALEBAG_BAG, *DEFINE_ALEBAG_HOLE, and *DEFINE_ALEBAG_INFLATOR  to define ALE type AIRBAG in modular way
BAGID1 - BAGID8
HOLEID1 - HOLEID8
INFLID1 - INFLID8
NX, NY, NZ, ARSNID, IDCENT, EXSID, LX, LY, LZ,  ITRANS, UIDAIR, ATMOST, ATMOSP, GC, CC, MWD, SPSF, SWTIME, HG, NAIR
ALE MESH OPTION (GENERATE MESH, SELECT MESH)
*AIRBAG_ALE
Provides a simplified approach to defining the deployment of the airbag using the ALE capabilities with an option to switch from the initial ALE method to control volume method at a chosen time.
Title, SIDTYP, MWD, SPSF, ATMOST, ATMOSP, GC,
CC, TNKVOL, TNKFINP, NQUAD, CTYPE, PFAC, FRIC, FRCMIN, NORMTYP, ILEAK, PLEAK, IV_PSETID, IBLOCK, VNTCOF, NX, NY, NZ, MOVERN, ZOOM, SWTIME, HG, NAIR, NGAS, NORIF, LCVEL, LCT, MWAIR, INITM1, AIRA,
AIRB, AIRC
PFAC_Option
IVTYPE (PartSetID, PartID, Segment Set)
NX_NY_Option
*AIRBAG_HYBRID_
CHEMKIN_ID
Title, SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, LCIDM, LCIDT, NGAS,
DATA, ATMT, ATMP, RG, HCONV, C23, A23
LCIDM_Cubic_Interp
LCIDT_Cubic_Interp
*AIRBAG_HYBRID_ID
Title, SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, ATMOST, ATMOSP, ATMOSD, GC, CC, C23, LCC23, A23, LCA23, CP23, LCCP23, AP23, LCAP23, OPT, PVENT, NGAS
LCC23_Relative_Pressure
A23_Option
Jetting
Reference Geometry
*AIRBAG_HYBRID_
JETTING_ID
Title, SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, ATMOST, ATMOSP, ATMOSD, GC, CC, C23, LCC23, A23, LCA23, CP23, LCCP23, AP23, LCAP23, OPT, PVENT, NGAS, XJFP, YJFP, ZJFP, XJVH, YJVH, ZJVH, CA, BETA, XSJFP, YSJFP, ZSJFP, PSID, NODE1, NODE2, NODE3, NREACT
Control
A23_Option
Jetting
Reference Geometry
*AIRBAG_HYBRID_
JETTING_CM_ID
Control
A23_Option
Jetting
Reference Geometry
*AIRBAG_INTERACTION_ID
Define two connected airbags which vent into each other
AB1, AB2, AREA, SF, PID, LCID, IFLOW
LCID_orificeAreaCurve
LCID_orificeCoeffCurve
*AIRBAG_LINEAR_FLUID_
ID
Title, SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, BULK, RO, LCINT, LCOUTT, LCOUTP, LCFIT, LCBULK, LCID
ControlVolHelp
*AIRBAG_LOAD_CURVE_
ID
Title, SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, STIME, LCID, RO, PE, P0,
T, T0
ControlVolHelp
*AIRBAG_PARTICLE
To define an airbag using the particle method.
SID TYPE1, SIDTYPE2, BLOCK, NPDATA, FRIC, IRPD, NP, UNIT, VISFLAG, TATM, PATM, NVENT, TEND, TSW, IAIR, NGAS, NORIF, NID1, NID2, NID3, CHM, CD_EXT
*AIRBAG_REFERENCE_
GEOMETRY_BIRTH
If the reference configuration of the airbag is taken as the folded configuration, the geometrical accuracy of the deployed bag will be affected by both the stretching and the compression of elements during the folding process.
BIRTH
*AIRBAG_REFERENCE_
GEOMETRY_BIRTH_RDT
BIRTH
*AIRBAG_REFERENCE_
GEOMETRY_RDT
n/a
*AIRBAG_SHELL_
REFERENCE_GEOMETRY
n/a
*AIRBAG_SIMPLE_
AIRBAG_MODEL_ID
Title
SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, CV, CP, T, LCID, MU, A,
PE, RO, LOU, TEXT, A, B, MW, GASC
ControlVolHelp
Mu_Option
A_Option
ReferenceGeometry
*AIRBAG_SIMPLE_
PRESSURE_VOLUME_ID
Title
SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, CN, BETA, LCID, LCIDDR
ControlVolHelp
CN_LCID_Option
*AIRBAG_WANG_NEFSKE
_ID
Title
SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, CV, CP, T, LCT, LCMT, TVOL, LCDT, IABT, C23, LCC23, A23, LCA23, CP23, LCCP23, AP23, LCAP23, PE, RO, GC, LCEFR, POVER, PPOP, OPT, KNKDN, TEXT, A, B, MW, GASC
Pop, Jetting, ReferenceGeometry
*AIRBAG_WANG_NEFSKE
_JETTING_ID
Title
SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, CV, CP, T, LCT, LCMT, TVOL, LCDT, IABT, C23, LCC23, A23, LCA23, CP23, LCCP23, AP23, LCAP23, PE, RO, GC, LCEFR, POVER, PPOP, OPT, KNKDN, TEXT, A, B, MW, GASC, XJFP, YJFP, ZJFP, XJVH, YJVH, ZJVH, CA, BETA, XSJFP, YSJFP, ZSJFP, PSID, ANGLE, NODE1, NODE2, NODE3
MultipleJetting, CA_Option
*AIRBAG_WANG_NEFSKE
_JETTING_CM
Title
SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, CV, CP, T, LCT, LCMT, TVOL, LCDT, IABT, C23, LCC23, A23, LCA23, CP23, LCCP23, AP23, LCAP23, PE, RO, GC, LCEFR, POVER, PPOP, OPT, KNKDN, TEXT, A, B, MW, GASC, XJFP, YJFP, ZJFP, XJVH, JSVH, ZJVH, CA, BETA, XSJFP, YSJFP, ZSJFP, ANGLE, NODE, NREACT
*AIRBAG_WANG_NEFSKE
_JETTING_POP_ID
Title
SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, CV, CP, T, LCT, LCMT, TVOL, LCDT, IABT, C23, LCC23, A23, LCA23,CP23, LCCP23, AP23, LCAP23, PE, RO, GC, LCEFR, POVER, PPOP, OPT, KNKDN, TEXT, A, B, MW, GASC
MultipleJetting; CA_Option
BETA Option
CM
Reference Geometry
*AIRBAG_WANG_NEFSKE
_JETTING_POP_CM
Title
SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, CV, CP, T, LCT, LCMT, TVOL, LCDT, IABT, C23, LCC23, A23, LCA23, CP23, LCCP23, AP23, LCAP23, PE, RO, GC, LCEFR, POVER, PPOP, OPT, KNKDN, TEXT, A, B, MW, GASC, TDP, AXP, AYP, AZP, AMAGP, TDURP, TDA, RBIDP, XJFP, YJFP, ZJFP, XJVH, YJVH, ZJVH, CA, BETA, XSJFP, YSJFP, ZSJFP, PSID, ANGLE, NODE, NREACT
*AIRBAG_WANG_NEFSKE
_MULTIPLE_JETTING_CM_
ID
Title, SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, CV, CP, T, LCT, LCMT, TVOL, LCDT, IABT, C23, LCC23, A23, LCA23,CP23, LCCP23, AP23, LCAP23, PE, RO, GC, LCEFR, POVER, PPOP, OPT, KNKDN, IOC, IOA, IVOL, IRO, IT, LCBF, TEXT, A, B, MW, GASC, XJFP, YJFP, ZJFP, XJVH, YJVH, ZJVH,  LCJRV, BETA, XSJFP, YSJFP, ZSJFP, PSID, ANGLE, NODE1, NODE2, NODE3, NREACT
*AIRBAG_WANG_NEFSKE
_MULTIPLE_JETTING_ID
Title, SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, CV, CP, T, LCT, LCMT, TVOL, LCDT, IABT, C23, LCC23, A23, LCA23,CP23, LCCP23, AP23, LCAP23, PE, RO, GC, LCEFR, POVER, PPOP, OPT, KNKDN, TEXT, A, B, MW, GASC, XJFP, YJFP, ZJFP, XJVH, YJVH, ZJVH,  LCJRV, BETA, XSJFP, YSJFP, ZSJFP, PSID, ANGLE, NODE1, NODE2, NODE3
BETA_Option
CM
ReferenceGeometry
*AIRBAG_WANG_NEFSKE
_MULTIPLE_JETTING_POP
_CM_ID
Title
SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, CV, CP, T, LCT, LCMT, TVOL, LCDT, IABT, C23, LCC23, A23, LCA23, CP23, LCCP23, AP23, LCAP23, PE, RO, GC, LCEFR, POVER, PPOP, OPT, KNKDN, TEXT, A, B, MW, GASC, TDP, AXP, AYP, AZP, AMAGP, TDURP, TDA, RBIDP, XJFP, YJFP, ZJFP, XJVH, YJVH, ZJVH, LCJRV, BETA, XSJFP, YSJFP, ZSJFP, PSID, ANGLE, NODE, NREACT
*AIRBAG_WANG_NEFSKE
_ID
Title
SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, CV, CP, T, LCT, LCMT, TVOL, LCDT, IABT, C23, LCC23, A23, LCA23,CP23, LCCP23, AP23, LCAP23, PE, RO, GC, LCEFR, POVER, PPOP, OPT, KNKDN, TEXT, A, B, MW, GASC, XJFP, YJFP, ZJFP, XJVH, YJVH, ZJVH,  LCJRV, BETA, XSJFP, YSJFP, ZSJFP, PSID, NODE1, NODE2, NODE3
BETA Option
CM
Reference Geometry
*AIRBAG_WANG_NEFSKE
_POP_ID
Title
SIDTYP, RBID, VSCA, PSCA, VINI, MWD, SPSF, CV, CP, T, LCT, LCMT, TVOL, LCDT, IABT, C23, LCC23, A23, LCA23,CP23, LCCP23, AP23, LCAP23, PE, RO, GC, LCEFR, POVER, PPOP, OPT, KNKDN, TEXT, A, B, MW, GASC, TDP, AXP, AYP, AZP, AMAGP, TDURP, TDA, RBIDP
Reference Geometry
*DEFINE_ALEBAG_BAG
Defines the surface that constitutes the airbag's outer surface for ALE airbag
CVBAG, IBLOCK, VTCOEF, VENTSID, NQUAD, CTYPE, PFAC, FRIC, FRCMIN, NORMTYP, ILEAK, PLEAK, NORM, START, END
SID TYPE (Part Set ID, Part ID)
VENTYP (Part Set ID, Part ID, Set Segment)
PFAC_Option
*DEFINE_ALEBAG_HOLE
Defines the surface that constitutes the vents for ALE airbag
SID_SET, NQUAD, XOFF, NFOLD, XCLEN
*DEFINE_ALEBAG_
INFLATOR
Defines the inflator for ALE airbag
NGAS, NORIF, LCIDVEL, LCIDT
*DEFINE_CPM_BAG_INTERACTION
Allows interaction between two particle bags.
BagID1, BagID2
*DEFINE_CPM_CHAMBER
Defines airbag chambers for air particle initialization or chamber interaction.
NCHM
*DEFINE_CPM_GAS_PROPERTIES
Defines extended gas thermodynamic properties.
Xmm, Cp0-Cp4, Ut0-Ut4, Chm_ID, Vini
*DEFINE_CPM_VENT
Defines extended vent hole options.
C23, LCTC23, LCPC23, ENH_V, PPOP, C23UP, IOPT, JT, IOPT1
*INITIAL_FOAM_
REFERENCE_GEOMETRY
The reference configuration allows stresses to be initialized in the following hyperelastic material models: 2, 7, 21, 23, 27, 31, 38, 57, 73, 83, 132 and 181.
n/a
hmtoggle_arrow1PAM-CRASH 2G
Supported Card
Solver Description
Notes
BAGIN
Airbag definition
Pa; Ta; Ru; INACT: YPV; RHOPV; TIPV; AHEAT; LCTRAN; NCYFR;
CHAMBER
Multiple chamber definitions
AHEAT, LCTRAN, TITLE
DISP_EXT_SKIN_CARDS
WALL_OPENING
WALL_FABRIC
INI_COND
LEAKAGE
INFLATOR
END_BAGIN
Terminates the whole general airbag definition
END_CHAMBER
Ends each chamber description
EXT_SKIN
Chamber outer skin elements
Sub-keyword of CHAMBER
FPM
FPM definition card
Sub-keyword of BAGIN
FPM_HOLE
Hole for SPHCEL
GAS
Chamber GAS definition
GEN_INI_COND
Chamber gas initial condition
INFLATOR
Airbag inflator definition
INI_COND
Initial condition of gas
JET
Jet definition
LEAKAGE
Vents and holes definition in airbag
LOCAL_H
FPM - Local smoothing length card
WALL_FABRIC
Define chamber wall fabric
S, MATFAB, NLD
WALL_OPENING
Chamber wall opening
NUL_SHELL, S, MATOP, COP, NLDCOT, NLDCOP, IFLOPT, VEN_AREA, IOPEN, OPIN, OPOUT
NUMNULSHELL
NUM_VENAREA
See Also:
Model browser
Entities & Solver Interfaces
Model Setup
