Create new element types from the Create ETType dialog.
Specify the following options and click Create to create the element type and return to the ET Type macro, or Create/Edit to create the element type and open the card image panel in HyperMesh to specify the key options for the element type.
Element Ref No |
Type an identification number for the real set. If you do not specify a value, a number will be automatically provided that is one higher than the highest current real set ID number. |
Element Type |
Select an element type from the drop-down list. The element types are listed in groups sorted by type, as shown in the image below. |
