Engineering Solutions
Edit ETType Dailog
Edit ETType Dailog
Edit ETType Dailog
Edit existing element types from the Edit ETType dialog.
Modify the following options and click Update to save the changes to the element type. Then click return to return to the ET Type macro. You can also click Edit Key Options to modify the key options for the element type in the HyperMesh card image panel.
Element Ref No
This field is initially populated with the reference number of the element type you have selected to edit. You can change the reference number to any number that is not already used by an existing element type.
Element Type
This field is initially populated with the type of the element type you have selected to edit. You can select another element type from the drop-down list. The element types are listed in groups sorted by type, as shown in the image below.
If you make changes to an ET Type, you must click Update to reflect the changes in the card image.
ansys_createettype_macro3
