Discrete Mapping of Temperatures or Pressure from a .csv File |
1. | Import the model containing the new mesh into Engineering Solutions. |
2. | In the Model browser, right-click and select Create > Field from the context menu. |
3. | In the Entity Editor, edit the field's corresponding attributes. |
a. | Set Type to discrete. |
b. | Set System type to real. |
c. | Set Source to csv file. |
d. | In the File field, locate the .csv results file with temperatures or pressures. |
4. | In the Model browser, right-click on the field entity and select Realize from the context menu. |
5. | In the Field Realization dialog, define realization settings. |
a. | Using the Entity selector set to Node, select nodes to be mapped. |
b. | Set Field type to temperature. |
c. | Set Interpolation to proximity (finds the closest nodes) or linear (finds nodes using the inverse distance average). |
d. | In the Tolerance field, enter the perpendicular projection tolerance. Nodes outside of this limit will not be mapped (limitation in 14.0). |
Note: | Nodes outside of this limit will not be mapped. |
e. | Click Apply. Temperatures from the .csv file are mapped to the new mesh. |
f. | Click Contour to see the mapping. |
