Engineering Solutions
Element Based Surface: Optional Parameters Tab
The Optional Parameters tab allows you to define optional parameters for the *SURFACE card.
The supported parameters are:
Standard.3D/2D template: Trimming of open free surface, Property selection
Explicit template: Max ratio, Scale thickness, Region type for adoptive meshing, No offset and No thickness.
See the Abaqus Online Documentation for a detailed description of these parameters.  Click on the Update button to activate the Optional Parameters selection in the Engineering Solutions database.
contact_mgr_optional_parameters
