Engineering Solutions
Line Meshing
Line Meshing
Line Meshing
1D mesh allows accurate testing of connectors (such as bolts) and similar rod-like or bar-like objects that can be modeled as a simple line for FEA purposes.
One dimensional elements currently supported include bar2s, bar3s, rigid links, rbe3s, plots, rigids, rods, springs, welds, gaps, and joints. The following list indicates the storage capabilities and purpose of each of the 1D elements.
1D Element
Stores
Purpose
Bar2
A property reference
A local axis vector
Pin flags
Offset vectors
Optional orientation nodes
Supports complex beams.
Bar3
Property reference
Local axis vector
Pin flags
Offset vectors
Note:  bar3s contain a third node designed to supported second order beams.
Gap
Property reference
Supports gap elements.
Joint
Property reference
Optional orientation nodes or system(s)
Supports kinematic joint definitions supplied with Safety Analysis Codes.
Plot
A reference to two nodes
Supports display type elements.
RBE3
A degree of freedom at each node
Weight at each node
Supports NASTRAN RBE3 elements.
Rigid link
A degree of freedom code
One independent node
Multiple dependent nodes
Supports rigid elements with multiple nodes.
Rigid
Supports rigid elements.
Rod
Supports simple beams.
Spring
An optional orientation vector
Supports springs or damper.
Weld
Supports weld elements.
Note:The 1D element-building panels are located from the Meshing > Create menu options. Plot elements are generated in the Edit Element, Line Mesh, Elem Offset, Edges, or Features panel.
