Engineering Solutions
Load Step: CFILM: Parameter Tab
The Parameter tab allows you to define optional parameters for the *CFILM card.
The supported parameters are:
Amplitude, Film Amplitude, OP, and Region Type
See the Abaqus online documentation for a detailed description of these parameters.  Click Update to activate the optional parameter selection in the database.
step_mgr_cfilm_parameter_tab
See Also:
Load Step: CFILM
