The Define tab allows you to define a *CRADIATE card on node sets only. Engineering Solutions does not support *CRADIATE on individual nodes.
The Define CRADIATE on Node sets option defines *CRADIATE on node sets.
This dialog has a node sets drop down menu containing a list of the existing node sets. It also has a data line input table with the following columns:
Nodeset |
The name of the node sets. Node sets are added or removed using |
Area |
The area associated with the nodes. |
Ref temp |
Ambient reference temperature. |
Emissivity |
Surface emissivity. |
For tips on entering information and navigating in the Define tab, see Step Manager Tab Environment.
The Define CRADIATE on: Node sets option has the following buttons:
Review/Reset Set |
Reviews the selected node sets by highlighting them in the graphics. Right-click Review to clear the review selections. |
Create/Edit Set.. |
Opens the Entity Sets panel in Engineering Solutions. When you finish creating/editing the set, click return. The Step Manager is updated with the new set appearing in the node set list. |
Adds the selected node set from the drop-down menu to the data line table on the right. |
Deletes the selected node set from the data line table. |
Review/Reset |
Reviews the selected node set in the data line table. Right-click Review to clear the highlighted selections. |
Update |
Updates the database with the data lines defined in the table. By default, Engineering Solutions does not create a display for loads defined with sets. |
