Engineering Solutions
Load Step: File Format
The File format option in the tree allows you to define the *FILE FORMAT card.  This option is available when a standard Abaqus template is loaded.
The supported attributes are: File format and Zero increment.
See the Abaqus online documentation for a detailed description of these attributes.  Click Update to activate the monitor attributes defined in the HyperMesh database.
step_mgr_file_format
See Also:
Abaqus Step Manager Step Tab
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
