Engineering Solutions
Load Step: File Output
The File output option in the tree allows you to define the *FILE OUTPUT card.  This option is available when the Abaqus explicit template is loaded.
The supported attributes are: File output, Number interval, and Time marks.
See the Abaqus online documentation for a detailed description of these attributes.  Click Update to activate the monitor attributes defined in the HyperMesh database.
See Also:
Abaqus Step Manager Step Tab
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
