Engineering Solutions
Load Step: Inertia Relief
The Inertia relief dialog allows you to define and edit the *INERTIA RELIEF card.  To open the dialog in the Load Step window, select Inertia relief from the tree and a load collector from the Load collector table.
The dialog contains two tabs:
Define
Parameter
step_mgr_inertia_relief
See Also:
Load Collector
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
