Engineering Solutions
Load Step: Inertia Relief: Define Tab
The Define tab allows you to define * INERTIA RELIEF cards.
Activate the Inertia relief check box to make the *INERTIA RELIEF load active for the current load collector.
There are two data line options available:
Free direction
Integer list of degrees of freedom identifying the free directions
Reference points
Global X, Y, and Z-coordinates of the reference point.
Click Update to activate the data line selection in the database.
See Also:
