»Click here to display Table of Contents« Browsers > Utility Menus > Abaqus Utility Menu > Step Manager > Abaqus Step Manager Step Tab > Abaqus Step Manager Load Step Dialog > Load Step: Output Request > Load Step: Output Request: Data File (.dat):
The Define tab allows you to enable the Node Print, Element Print, Contact Print, and Energy Print tabs, which are used to define the *Node Print, *Element Print, *Contact Print, and *Energy Print cards.
