The Data file (.dat) dialog allows you to define and edit the output requests for the data file. Supported keywords are *NODE PRINT, *ELEMENT PRINT, *CONTACT PRINT, and *ENERGY PRINT. To open the dialog in the Load Step window, select Data File (.dat) from the tree and an output block from the Output block table.
The dialog contains five tabs:
