Load Step: Output Request: Result File: Energy File |
The Energy File tab allows you to define *ENERGY FILE for the selected Output block. The following parameters are supported: Elset and Frequency.
The Energy File tab contains the following buttons:
Create/Edit… |
Opens the Entity Sets panel. When you finish creating/editing the set, click return. The Step Manager is updated with the new set appearing in the element set list. |
Review |
Reviews the selected element sets by highlighting them in the HyperMesh graphics. Right-click on the Review button to clear the review selections. |
Update |
Updates the HyperMesh database with the data lines defined in the table and the parameters. |
