The Result file (.fil) dialog allows you to define and edit the output requests for the Result file. Supported keywords are *NODE FILE, *ELEMENT FILE, *CONTACT FILE, and *ENERGY FILE. To open the dialog in the Load Step window, select Result File (.fil) from the tree and an Output block from the table.
The dialog contains five tabs:
