»Click here to display Table of Contents« Browsers > Utility Menus > Abaqus Utility Menu > Step Manager > Abaqus Step Manager Step Tab > Abaqus Step Manager Load Step Dialog > Load Step: Output Request > Load Step: Output Request: Result File (.fil):
The Define tab allows you to enable the Node File, Element File, Contact File, and Energy File tabs, which are used to define the *Node File, *Element File, *Contact File, and *Energy File cards, respectively.
