Load Step: Output Request: ODB File: Energy Output |
The Energy Output tab allows you to define *ENERGY OUTPUT for the selected Output block. The following parameters are supported: Elset and Variable. Activate/deactivate the check boxes in the tree on the Energy Output tab to add/remove identifier keys in the table. The data lines added in this manner have a gray background, indicating they cannot be manually edited. You may also add user-defined identifiers by typing them directly into the table. The user-defined data lines appear with a white background, indicating they are editable.
Right-click on the Data lines table to display menu options. The available options are Cut, Copy, Paste, Add row, and Delete row.
The Energy Output tab has the following buttons:
Create/Edit… |
Opens the Entity Sets panel. When you finish creating/editing the set, click return. The Step Manager is updated with the new set appearing in the element set list. |
Review |
Reviews the selected element sets by highlighting them in the graphics. Right-click on the Review button to clear the review selections. |
Update |
Updates the database with the data lines defined in the table and the parameters. |
