Engineering Solutions
Load Step: Temperature
The Temperature dialog allows you to define and edit the *TEMPERATURE card.  To open the dialog in the Load Step window, select Temperature from the tree and a load collector from the Load collector table.
The dialog contains three tabs:
Define
Delete
Parameter
step_mgr_temp
See Also:
Load collector
Abaqus Step Manager: Load Step Dialog
Abaqus Step Manager Overview
