Engineering Solutions
Load Step: Temperature: Define Tab
The Define tab allows you to define *TEMPERATURE cards on individual nodes or geometry (surfaces, points, lines).  You can also define the temperature on node sets
It is recommended that you do not use *TEMPERATURE and *BOUNDARY with dof 11 together in a load collector in Engineering Solutions.  If you need to use multiple types of temperature in the same STEP, define each type in a separate load collector and add them to the same load step.
You can define *TEMPERATURE on nodes, geometry, or node sets.  For Define Temperature on:, the following options are available:
Nodes or geometry
Node sets
The layout of the Define tab changes, based on your selection.
See Also:
