Engineering Solutions
Mass Menu
Mass Menu
Mass Menu
The Mass menu focuses on various options to manage the mass of individual components as well as complete crash model assembly. The menu varies, depending on the solver that is loaded.
mass_menu_rad
crash_mass_menu_lsdyna
crash_mass_menu_pamcrash
RADIOSS
LS-DYNA
PAM-CRASH
ADMAS Manager
Displays all masses in the model; displays individual masses; creates new and edits existing, simple and advanced mass formulations; and views, finds attached and updates details of individual ADMAS, though the card editor and the Admas panel.
MASS Manager
Displays all masses in the model.
Node Mass
RADIOSS user profile: Opens the Admas panel with the elem types field automatically set to M-ADV0.
LS-DYNA user profile: Opens the Masses panel with the elem types field automatically set to MASS.
Part Mass
LS-DYNA user profile: Create, edit and review mass on nodes through the Masses panel with elem types set to MASS_PART.
Mass Trimming
Point Mass
Opens the Connectors: Apply Mass panel with the mass type field automatically set to point mass.
RBE3 Mass
Opens the Connectors: Apply Mass panel with the mass type field automatically set to rbe3 mass.
Rigid Link Mass
Opens the Connectors: Apply Mass panel with the mass type field automatically set to rigidlink mass.
Rigid Mass
Opens the Connectors: Apply Mass panel with the mass type field automatically set to rigid mass.
Mass Calc
Obtain the mass, area and/or volume of a selected group of elements, solids or surfaces.
Mass Summary
Obtain a summary of component element counts or element properties of the current model.
See Also:
Crash Application
