The Optional Parameter tab allows you to define optional parameters for the *SURFACE card.
The supported parameters are:
• | Standard.3D/2D template: Trim |
• | Explicit template: Max ratio, Scale thickness, Region type, No offset and No thickness. |
See the Abaqus Online Documentation for a detailed description of these parameters. Click on the Update button to activate the optional parameter selection in the Engineering So0lutions database.
